Just wanted to share these $100 off coupon codes for the 12.8V 200Ah GoKWh LiFePO batteries that they have listed at batteryfinds.com right now (a 24V 100Ah model is also discounted at the same rate, with a different coupon code, along with $60 off of the 12V 100Ah). These batteries are in the "China stock" section of their site, and consequently I imagine will take some time to arrive.
The 12.8V 100Ah variation of this battery was recently reviewed, thoroughly, by sunshine_eggo, and reported the following:
Conclusion:
The full review can be found here:
https://diysolarforum.com/threads/12-8v-100ah-gokwh-review.81497/
Coupon codes:
I read through the thread above, and could find no mention of the larger batteries, or coupon codes, so I'm sharing those here. I only happened to stumble across these discount codes while searching for something else on that site; and so I put a few of these in my cart and applied the coupon code, just to see if it was legit...and it did in fact incorporate that discount! I am currently ordering some raw 230Ah cells to make an 8s2p 25.6V battery pack myself, but I can't help but think if I wasn't doing that, these with BYD cells, a JBD BMS, and a $100 discount would be a feasible option for my application.
[P.S. If this thread would be more appropriate as a reply to the initial review, I'd be happy to put them over there.]
EDIT: the above are only claims made by the manufacturer, and this detail is not yet substantiated.The cells are Grade A BYD cells conforming to the above. The BMS is also JBD
Conclusion:
If I were in the market for an inexpensive 12.8V 100Ah battery without low temp charge protection, this would be on my list for consideration.
Coupon codes:
$60 off 12.8V 100Ah coupon code: | $100 off 12.8V 200Ah coupon code: | $100 off 25.6V 100Ah coupon code: |
GW12100BTLCD | GW12200BTLCD | GW24100BTLCD |
