This should not be this hard to do. I got a new 6000XP installed and am at the point of battery comms. Apparently I need to update firmware to get the inveter to see the batteries. I have 2 cables 1) that has the 2 wires in the rj45 end and it works with bms test on life4 batteries. I try using it with the LLV2's using bms tools and the red box never goes green. So I tried the other cable which is all cat5 wires in RJ45 end but that doesn't work either. All dip switches on or off to get the "64" address either way doesn't work also using 9600 or 19200. I am in the battery comm plug not the 485 one as the SS video shows. Can someone shoot a detailed pic of the cable and the proper dip switch settings for a 6 switch V2 battery.
