help on fusing solar panels.
Joe_
I have 28 used sharp 235 volt panels.
The label on the panels reads thus:
Maximum power 235 watt
open circuit voltage 37V
short circuit current 8.6A
Rated voltage 30V
Rated current 7.84 A
Maximum system voltage 600 v
Maximum series fuse 15 amps
I am making 4 strings of 7 panels each then paralleling 2 strings of 7 panels to get a nominal output of 296 volts @17.2 amps.
I'm connecting everything with 30 amp pv wire.
I'm placing 4 inline 15 amp fuses, one in each string of 7 panels inline before where I connect them in parallel.
Does this sound like I am meeting code? Is there any convention on where the fuses should be placed in the series string? Or just where they are easily accessible?
Thanks.
Thank you that is exactly what I was hoping for. You saved me buying 4 expensive fuse holders with fuses.
Glad to see that. I would recommend also asking for extra eyes on your Voc, since that’s can be an insta kill on the SCC/MPPT in the winter.
