I live in the Philippines with two wire 240v 60hz only power grid. I bought this brand new ABB PVI-5000-OUTD-US-A in the hope of using it in my country. However when I connected everything and powered the system up the inverter did its checks and had a "voltage out of range" error. I believe this is a USA model set for 120/240v it is looking for the neutral to make 120v? Is this a correct assumption?
My question is, can I set the voltage parameter for 240v only and if so what is the procedure to change the voltage? I appreciate any help. Thanks!
