Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,844
I would recheck all the connections and you can also swap the cell location to see if the reading will follow.
Can you ohm out connections all the way from cell terminal to BMS PCB?
I would guess extremely high contact resistance, megohms or essentially no contact in the harness so BMS input current upsets its voltage readings.
Given DMM readings of cells looks OK, what swapping would do is just jiggle wires and remake screw connections. If these had been believable readings, then swapping would possibly show issue follows cell.
Suggestion to OP, once you have BMS connected please upload clear pictures for us to look at and verify that it is hooked up correctly.
It really sounds like there is a connection problem somewhere. Do you have a crimp tool and crimp connectors (for the balance leads)?Do you think it’s a problem with the crimping on the balance leads or the blue B- leads ?
Also set the cell undervoltage to 2500. Then be sure to write to BMS.As requested thanks budd, this is the main one I need to set yes?
I'm not sure about the vendor you purchased from, but all that I am aware of have used m6 size for the terminals, and 1/4 inch should be perfect (for the battery end of the balance leads). I am not familiar with the Overkill BMS, but most vendors use 20 or 22 awg wires with JST connectors (.1 inch, or 2.54 millimeter spacing).Yes I crimped them myself I’m going to take it off and redo them and send photos, the exposed metal was super small and the ring connectors I got are for 14-16 guage wire bc I needed a 5/16 ring
The openings to the blue are way too big for the wire
I had some smaller red one that were appropriate for the wire size but the ring was too small
Install Bay Vinyl Terminal Ring Connector 5/16 Inch 16/14 Gauge 100 Pack Blue - BVRT516 https://www.amazon.com/dp/B005V9V27...abc_EN29P364N77APKWE0AZX?_encoding=UTF8&psc=1
Color code for crinmp connector:Yes I crimped them myself I’m going to take it off and redo them and send photos, the exposed metal was super small and the ring connectors I got are for 14-16 guage wire bc I needed a 5/16 ring
Yes, that's what I was thinking as well, I also thought about maybe wires crossed or shorted (i.e. wires attached to the wrong cell, etc).A bad crimp at the ring terminal should present as low voltage not high.
Just to be sure I'd walk the pins at the bms end of the harness.
Anyone else feel like translating that?
Yes, all the voltages add up to the reported battery voltage, I noticed that as well.If one connection being bad is presented as low cell voltage, the adjacent cell will be high voltage.
Could be floating, could be tugged by nA input current of electronics.
3.146 + 2.892 + 3.889 + 3.31 = 13.237
13.237 / 4 = 3.31 V per cell
But I'm not sure how the BMS calculates voltages per cell, a bad crimp might show as low on the cell it is supposed to measure, and then high on the next cell?
