I’m looking to use solar to power a battery charger that requires 415v 20KW.
The battery charger is used to charge batteries that are 80V 404ah.
Or should I be looking at charging the batteries seperate and not using solar to power the battery charger appliance.
I will need a 3 phase inverter.
Some overall advice would be great as I have found myself in a bit of a hole right now.
