jeffster1978
I have an issue that I hope you can help me with. So I have two 36 volt Step Up converters wired in parallel that I charge up my AC180 and a AC300 from a 12 volt battery. I recently built a 48 volt step-up converter to charge my AC300 exclusively. So here is my issue.. 48v step-up converter will easily charge my AC180 at 475 W no problem. However when I try to run it on the AC300 the voltage and wattage are crazy erratic. Meaning the voltage and watts are jumping all over the place a mile a minute. I am charging it through the solar charging inputs and no matter what I do or what setting I put it on it will not work. The funny thing is it will work on the AC180. And the 36 V step-up converter will work just fine on both. What possibly could be the problem?? My AC300 apparently is allowed to take in 2400 watts of solar charging. And I know there is no way there is an over voltage because it is reading 48 volts and it would be nowhere near close to 2400 Watts input. Any suggestions cuz I'm pulling my hair out! LOL Thanks.
