ExceedSolar
I am a newcomer to this, including the diy solar in general. Current setup is 12-100 watt HQST panels. I have a 100amp charge controller from oocycoo. Or maybe it's spelled ooycyoo. Anyways, I have this hooked to 3-100ah redodo batteries, with a 2000 watt inverter. I just need help with the proper and best wiring solution. I currently have the panels in 4 series 3 parallel. I sized the wire based on distance, and rated power, and believe I have done all that properly. However, I don't feel I'm getting the most from my panels, and wonder if perhaps I should wire them differently? Also, I have my batteries in parallel. Is this all the correct way? Thanks in advance for any assistance.
