Hello everyone!
How would you connect the following (click name for the item specification):
1) Panels x4
2) Inverter/Charger (1) or let me know if this weaker one would do as well: Inverter/Charger (2)
3) Battery x4 (1) or let me know if better: Battery x4 (2) or even Battery x4 (3)
4) Generator - somethign around this lines
Let me know which items would you prefer (regarding inverter/charger and battery options) and how would you make a schem of the connections. Do I need saparate charge controler when I want to have generator connected or I can simply connect it to the inverter/charger as the solar array. If I do need, which charge controler would you suggest? If I will connect everythign myself, which part would you warn me about? Where should I add (and what type) of circle breakers? And last, how would you connect (series/paralel) the array/batteries and how thick wire do you suggest to use?
Thank you in advance!
1) Panels x4
