Hi people. Looking to now add to my battery and inverter for a complete system. Alte calculator tells me I need a 1.2 kw array, 24A CC.
Ive selected a Victron smart solar 150/35 Cc, and 4 - 355w panels. Panels will be 2s2p. Using voltage drop calculators suggest 6awg output,cables and 10awg source cables.
im open to other suggestions. CC was within what I need, and panels were selected for no other reason than they are available locally for pickup.
questions:
1. Should I combine at array and run 6awg, or run 10awg to the CC and combine there? (50 feet from panels)
2. What “type” of cable? (6awg pv not available). I’m confused about then, mtw, welding etc. I know stranded is better, and Victron want “more” strands.
3. Ground wire inside conduit, or outside? 6awg solid is available at my Home Depot
id like to place Midnite spd’s on both ends of the array cable.
questions:
