andyriches
Would I be able to run the below
Sorry if it’s a silly question
I can get my hands on some 12v 160 APH batteries
I was hoping to run an air source pool heat pump from these
If I had 4 batteries in parallel that gives me 12v 640 APH
The kit says it’s 900 w so around 4amps
If I have an inverter will this run my air source heat pump ?
And then would I be able to charge the batteries with solar panels
Use the stores energy early hours and then charge the barriers during the day ?
