I've set up my inverter off grid with AC input (230v) without the CT, work mode AC+PV with CT setting off and on grid setting off. I only have 2 x 355W (ET-M660BH355WW) panels currently in series and they output ~75V (at the inverter), I understand that my panels voltage is below the MPPT range of 120 - 450V I only had 2 panels and I wasn't sure of the minimum DC spec before I bought the inverter since the alibaba listing was a bit confusing.
My problem is that I've measured the amps of the panels at the inverter and it reads around 3A, but once connected and running the inverter displays only 0.3A and that's only 22/23W, is this because of my voltage being below the MPPT range or is there something else that's the issue? I can upload pictures of how I've wired the inverter if that helps
