Do It Yourself
- Sep 9, 2022
- 12
Hi Everyone,
I have a Solis RHI hybrid inverter and I'm using this diagram to wire it.
![1662881098258.png 1662881098258.png](https://diysolarforum.com/data/attachments/111/111403-25c52cf5c6167e53b2e3f01328a3f5b9.jpg)
I will be wiring it very similar to this diagram but I'm having trouble wrapping my head around the consumer unit section.
![1662881575435.png 1662881575435.png](https://diysolarforum.com/data/attachments/111/111405-9ce374bdb6c3e1076b4bb9d9a6c0dfe7.jpg)
Where I've circled in blue here, would that part be a henley block?
![1662881636498.png 1662881636498.png](https://diysolarforum.com/data/attachments/111/111406-d42fbba2eda136280f4d3d404f69a7a8.jpg)
and then where I've circled in red, would that be a switch like this one? (this one is 63a)
![1662881754771.png 1662881754771.png](https://diysolarforum.com/data/attachments/111/111407-e412dec8431d5468fb5c0ffd0fdd29f4.jpg)
Finally, I struggle to see how the critical loads will have power on a normal day to day basis when the switch is set to inverter, because the AC OUTPUT that connects the critical loads only comes into play when EPS is activated?
Thanks for your help!
