Ahh, didn't realize Epever had an AIO.
Usually we hear of SCC, and people have had some issues with some models shutting off and having to be restarted.
The EPever UPower Inverter Charger series is a new hybrid inverter charger combining Solar & Utility grid charging and AC output, which adopts a
zhcsolar.com
If you can over-panel and program a modest charge rate optimized for battery, then it should sustain that charge rate for a range of sun conditions. And harvest max it is able to when inverter needs power.
Thanks Hedges, glad to hear your thoughts. Can you tell me what is an Isc spec?
"Isc" = Current (I), under short-circuit conditions. That's is what PV panel would put out if PV+ connected to PV-, under "Standard Test Conditions".
Normally a bit less, but could be higher under some lighting conditions.
Label gives Voc, Isc, Vmp, Imp, max fuse allowed. Data sheet gives temperature coefficients.
Use temperature coefficient from PV data sheet for Voc calculation, not the one from AIO data sheet!
Fuses and wires should be sized for 1.56x Isc. Normal circuits are sized 1.25x continuous current, and for PV an additional 1.25x multiple is applied.
SCC may have a reverse-polarity diode which would conduct PV array Isc if connected backwards. During SCC normal operation, it may draw up to Isc. A better design would limit what it draws to no more than it could handle. Some SCC if they detect over-voltage might use a FET to short the array, again carrying Isc.
PV Short Circuit Current- Isc (A) 8.85
So 2s2p would be 17.7A Isc.
I don't see a max Isc spec for AIO, only max power. They tend to quote max power, but some brands are designed to draw only what they want, not what is available. NO GUARANTEE THIS ONE WON'T DRAW EVERYTHING YOUR OVER-PANELED ARRAY CAN DELIVER, DAMAGING ITSELF!
