Don B. Cilly
Energetic energy padawan
Right, but "rated watts" does not necessarily equal "good charge", does it? :·)
A lot of people confuse daylight with sunhours. A sunhour is somewhat of an abstraction to describe the relative amount of power you are getting, related to latitude and season. When Hedges mentions "5 effective hours sunshine might be average, and 2 hours in winter", I believe he is referring to sunhours. It's just a kind of shorthand to quickly determine what you are likely to make in kWh in a day.I get 8 hours of good charge at equinox. At 38° latitude. 9 to 5 winter time, 10 to 6 summer one. 5 at (winter) solstice.
Maybe I just have good panels :·)
A "good" charge, for me, is about 40-50% of panel rating, mind you.
In your case, with getting ~50% or panel rating for 8 hours, thats saying you are getting ~4 sunhours.
The really best way to determine this empirically is to just count up the total number of kWh of power you made that day, and divide by the total number of watts of panels.I would say I get (on a sunny day) 40% for half an hour, 50-60 for an hour, 80-85% for 5 hours, 100% never (of rated power, eh) and then again 50-60 and 40, tapering to zero. By 12-1PM the batteries are usually full anyway.
There is a small town nearby, hense $4.50 per litre.
My Upower2000 has a max 30A charger and a Max PV open circuit voltage of 100V (at minimum operating temperature) and 92V (at 25 degrees environment temperature)
The PV has an open circiut voltage of 46.4V so please correct me if I am wrong, in series-parallel that would make 92.8V which is just over the maximum PV open circuit voltage at 25 degrees.
Thanks again Michael and Hedges. Could you please explain how you would set up my solar panels ( 4 x 400w, Maximum Power Voltage 38.6V and Maximum power Current 10.36A )
Hi Hedges, coldest temperature in the last 10 years is 15 degrees C.
2 x 12v fullriver 100A in series, so 200A 24V.
Yes not much, but got a great deal and really have no idea how long it will last. Pioneering as cannot find anything on the net comparable.
