Hello Friends,
I have been living in my bus for about 15 years. This is where I am now for the winter.
I have 8 200 AH 12 volt AGM batteries for 1600 AH. 1580 watts solar, 3000 watt 12 volt ProSine sine wave inverter/120amp charger, 2 outback MX60 charge controllers. My first set of bus batteries were Trojon L-16's, they lasted about 12 years before they started dying, I replaced them with 200 amp 12 volt AGM's.
I'm now thinking about Lithium batteries. Besides all the obvious reasons, I would save over 800 lbs..
I've spent most of the last 25 years living with lead acid batteries an solar panels boondocking mostly on the beach in Mexico. So for me, it's a new way of thinking.
My plan is for 16 280 AH LiFePO4 cells with BMS.
I need to decide the best way to layout the cells for 12 volts or do I even have a choice. Input from my solar panels are about 50 volts.
Also, The right BMS for the job. This is a little bit foggy.
Thanks for all the info here and thanks to Will for the videos.
Jerry Campbell
Jerry Campbell
