Joe del Sol
- May 10, 2022
- 8
Hi all. I'm trying to add a small PV system to my travel trailer for occasional boondocking use (lights and cell phone charging in the evening). The current house battery is an 80Ah AGM. (Upgrade to LiFePO₄ is in the future, but not yet). I understand an AGM charge rate should be from 0.1C (8A) to 0.2C (16A). Rates 0.2C and above are said to shorten battery life.
First iteration was a 100W panel ((Imp): 4.4A, (Vmp): 22.3V) + Renogy Wanderer 10 PWM. We generally camp in forested areas with broken shade (yes, not ideal for solar). In an attempt to capture more energy in those conditions, I ordered a Rover 20 MPPT and another (identical) 100W panel.
My questions:
1) The Rover 20 + 200W PV, under ideal conditions, would send too much current (0.2C) to the house battery. Is there a way to limit charging current to 10A?
2) Seems like an ideal setup (with this battery) would be a 10A MPPT (EPEver makes one) and over panel it (there's been discussion that it won't handle over panelling, but that's another discussion). I'd much rather buy and install one (larger) controller for use when we upgrade to LFP batteries, so I'm really hoping the Rover 20 would work somehow. Return it and get the EPEver instead?
3) After typing all this, just realized maybe the best compromise is wiring the two panels in parallel, using the old 10A PWM and returning the Rover 20. This would give max 8.8A charge to the battery, which is just over 0.1C, but of course, less power than an MPPT.
Thoughts? In short, what's the best way to use lots of PV real estate (because of the shade) while limiting charge current?
My questions:
