I'm looking for information on an inexpensive (but safe!!) DIY hack that would let me run some essential equipment (e.g., the well-pump and the circulating pump for the gas-fired furnace) during emergencies when the grid is down.
My existing solar setup was commercially installed, and it uses the Hoymiles HM-xxx family of micro-inverters. The system consists of three banks of about ten panels each, with a peak capacity of about 3 or 4 kW each. Each of the banks has its own 20 Amp, 2-pole breaker and the three breakers go to a manually operated DPST disconnect switch that can isolate the panels from the rest of the house wiring and the utility meter. What I would like to be able to do is to open that disconnect switch during a power outage and then attach some kind of simple DIY circuit directly to the solar panels that would spoof them into thinking that they are still connected to a grid so that they would continue producing power to either charge batteries or -- preferably -- to operate the appliances directly.
I have a 3 kW gasoline generator that I have used in the past during power failures, but I'd like to be able to use the solar panels instead (or in addition). My essential appliances (like the well pump, furnace, septic tank sump pump, etc.) are connected to the house wiring by plugs and receptacles instead of being hard-wired. So, during a power failure, I just unplug them from the house wiring and plug them into the generator as needed. But I would like to be able to plug them into the solar array instead. The biggest single motor that I need to deal with is the well-pump, which is about 1 or 1.5 HP; all the other stuff is relatively low power.
If anybody can point me to sources of information that are directly relevant to the Hoymiles system, I would greatly appreciate it. Thanks in Advance!
