Twitchr
Hi folks, apologize for the neive question, I just have a couple questions if I am going down the right path to DIY, and what more experienced people would suggest.
I'm convinced I want to do solar, but I'm sure if I am going to hit huge roadblocks after dropping a bunch of money. I was planning on hiring it all out, but the solar contractors that have come out feel like used car salesmen. After looking at the proposed systems, it appears less complex than what I had thought. I do not plan on doing battery backup.
I'm mostly concerned with the grid tie aspect, and inspections/permits. I have started going thru my utility (Consumers Energy in Michigan) portal to apply, and it lists contractor as a required field. My meter is on a barn (agricultural), and I have been told by some other farmers that Ag buildings are exempt from inspections, and as long as I have my livestock.in there I'm good. Researching that shows some truth to it, honestly I'm happy building everything to code anyway, but if no inspection could eliminate a hurdle than cool.
I guess my question for the forum is, should I be intimidated by the utility tie aspect and application to the power company?
Thanks for any responses.
Background: Tech Center electrician training for 1 year, rewiring a couple houses that I flipped, and Power Engineer day-job.
