Chadd
- Jul 13, 2022
- 92
Making multiple connections to storage batteries.
I have two batteries at present in parallel, there is one charge converter connected to them and an invertor.
I have two more charge converters to connect and more batteries to parallel up.
The batteries have the car battery type terminals.
As all the cables are heavy how is this normally managed.
I wondered if it would be ok to connect the three charge converters to a large block type connector, similar to the type used to split mains from the outside to different meters.
Then one set of leads to the battery, this would at least solve some of the problem.
The battery terminal connectors I have at present are standard car type ones, which do not lend themselves to lots of cables.
God Bless Chadd
God Bless Chadd
