Can someone explain how the BMS functionality works with multiple lifepo4 batteries.
For instance, if I have 2 x 260 amp hr batteries, configured in parallel, each with a 125 amp BMS, does that equate to maximum discharge of 125 amp or 250 amps?
Also, should one be able to run AC appliances, such as a coffee maker, microwave or a small toaster oven (not simultaneously of course) off of a 3,000 watt inverter?
Because, so far, we don’t seem to be able to do so, and hence need to figure out if the BMS is causing the inverter to cut out, due to the maximum discharge being deficient. And if so, would a 150 amp be sufficient; or would we need a 200 amp or even 250 amp BMS in order to run such items?
And, how does one even start to troubleshoot such an issue? The inverter just seems to be cutting out but we have no clue as to what the underlying cause might be other than possibly the BMS max discharge being inadequately low.
PS - We have not experienced issues with the inverter running the 3 way fridge/freezer on AC off the inverter while in transit, nor does it have any issues charging up the e-bike batteries either when we are stopped and camping. But it’s extremely disappointing to have enough battery storage capacity, and enough charging capacity to maintain/charge/top off the battery bank, and an inverter that should be capable to run the AC appliances, only to have something apparently not correct in the current configuration of this offgrid truck camper setup….
