Robbert
Hi, I would like to isolate my inverter from AC-in, and only allow AC-in if that is neccesary.
The reasons why I want this are:
1) the inverters that I use, use AC power if connected to the grid. If disconnected they use from the battery/solar
2) we have a very instable grid and after outages we see high peak voltages that could be harmfull for connected appliances
I bought two relays that I want to connect. In order to stop power in I can use just one relay on one leg.
That means that the other leg still has 110v going in.
Especially with regards to point two (disconnect from grid because of peak voltages), is it smart to add a relay to both legs?
I added a picture of the test setup (with two relays). Don't mind the colour of the cables since this is just a test on my desk.
