Hi,Recommended Charge Profile for DIY LiFePO4 Batteries *Sticky Post*
12V 4S LiFePO4 Battery w/ BMS: Absorption: 14.5V Float: 13.6V Inverter Cut-off: 10.7V-12V (depending on size of load and voltage drop etc) 24V 8S LiFePO4 Battery w/ BMS Absorption: 29V Float: 27.2V Inverter Cut-off: 21.4V-24V 48V 16S LiFePO4 Battery w/ BMS Absorption: 58V Float: 54.4V...diysolarforum.com
I have a newbie question regarding the recommended settings from Will: I do not have a "DIY" battery, but rather I am using 2 x Ampere Time 24V-100AH batteries in series (they have integrated BMS) with the Growatt SPR 3000TL LVM-ES. Should I configure the Growatt according to settings recommended by Will for a DIY 48V battery?
Thanks!
