JWLV
- May 27, 2020
- 585
I just watched Will's video about the Growatt inverter: No Battery Solar Power System: Growatt SPF 3000TL LVM-ES
So I started to read up on this particular inverter. It's a hybrid inverter, which includes a MPPT charge controller and inverter with three output modes.
I have a question about the output modes in one specific scenario.
The Growatt has 3 output modes.
Let's say my solar panels are providing a total of 500 watts at 150VDC and the Growatt is set to SBU Priority (3rd mode). It's a bright sunny day and the panels are producing exactly 500 watts. Let's also assume that my battery is completely drained and the Growatt just started the process of charging it from the panels. If I connect a load that's 750 watts, it's obvious that the solar panels can't provide all that power on its own (it'll be short by at least 250 watts). Since the battery will not be able to provide any power, the output mode will switch to utility.
My question is, will the Growatt cut off the solar panels completely from the output and draw the entire 750 watts from the utility or will it draw as much as it can (up to 500 watts) from the solar panels and the rest from utility?
I've also looked at several other similar hybrid inverters that have 3 output modes. Prices range from $400 to $900. A couple of them even look identical to the Growatt, just with a different name on the front.
- Utility first: Utility power your load as first priority, battery power and solar on when Utility not available.
- Solar first: Solar energy power your load, battery energy active when solar power doesn't work.
- SBU priority: Solar power first, then battery power, then Utility.
