Progress report!
Subscribed to Skillcat to get my EPA 608.
(I know the Mitsubishi is pre-charged, want the 608 for other things)
Was not impressed w/ the $$$ and quality of the mini-split wall brackets I found.
(The Mitsubishi bracket was over $300. For a stamped steel bracket....really?)
Bought some stainless steel angle and flat bar to make the wall bracket to mount the compressor.
Will TIG weld up something.
![lincoln_idealarc_tig_300.jpg lincoln_idealarc_tig_300.jpg](https://diysolarforum.com/data/attachments/227/227101-fdca15311f659cfe27c2c3db4ccffd7e.jpg)
Not sure if I should just buy a lineset or make my own.
Impressed w/ these copper sources:
Order Isotech UV Refrigerant Single Insulated Line Sets - Corrosion Resistant at ISCsales. Great Customer Service. Free Shipping on Qualified Orders.
iscsales.com
As the only producer of copper tube and fittings in the US, our proprietary technologies help provide the highest quality copper products in the industry.
muellerstreamline.com
Bought the Nylog "blue goo" to seal the flare, and the torque wrench for the flare nuts.
Found an "open box" Square D NEMA-3R disconnect, and a 15A Square D QO breaker on ebay for reasonable $$.
Already had a NEMA-1 box for the breaker, and had enough electrical conduit/fittings/ rolls of THWN #14 to do the power.
Found a Carbide bit for the 75mm hole through the concrete block wall.
Can't find a 3" wall sleeve, all the ones listed as 3 inch are not, according to the reviews. Will make my own wall sleeve.
Probably have enough PVC conduit & fittings to do the attic run, but not looking forward to crawling around up there in the heat......
Made a template to help establish the approximate location of the air handler.
![mitsubishi_template.jpg mitsubishi_template.jpg](https://diysolarforum.com/data/attachments/227/227102-d6262f19b80a31a3dcfabc3b5a8da0c1.jpg)
