SupraSPL
- Aug 28, 2022
- 222
The Fujitsu Halcyon 09LZAS1 (rebadged as RUUD) is 33.1 on SEER2 scale or 18EER or 530% efficient at 9K BTU rated cooling and 14.2 on HSPF2 scale or 5.3COP 530% efficient at 12K BTU rated heating. Max power draw can be as much as 2300W in powerful mode heating so it is available in 240V only. Cost was $1400+$100 tax free shipping from a high feedback eBay liquidator. Seller crated the condenser and the unit arrived in flawless condition.
Since my system is all 120V when off grid and the Fujitsu needs 240V I installed a dedicated 24V to 230V 60HZ inverter (Vevor 3000VA aio $300).
I installed the unit late November 2023 and so far it has been awesome. I can barely hear the indoor unit and the outdoor unit must be 100X quieter than my old R22 condenser, basically makes a slight buzzing sound with occasional slight demonic sound when compressor is running, can't even hear the fan. Outdoor unit is mounted on wall bracket and zero vibrations or sounds come through.
The RUUD/RHEEM version indoor unit is 36" wide and the Fujitsu version is 38.4", I think because of the lack of wifi module in the RUUD. I really needed to save few inches for this space, so that was awesome but the wifi would have been nice to have. Maybe I'll add an ir wifi device.
12K BTU easily keeps my 1500 sq ft upstate NY house warm (some rooms are closed off), even running in economy mode in December. When we get below 15F I will just run the woodstove unless I have excess power to burn off.
I put the condenser in a sunny spot hoping to gain a little efficiency. I don't mind the penalty during cooling season because I will have a glut of power then anyway.
Electricity was $0.18/kwh this month plus $17/month for service so if the outdoor temps are 25F or more and I am out of solar battery power, I switch the Fujitsu to the grid to conserve oil and firewood. When temps are in the 30s it takes about 750W or 18kwh/day to run the Fujitsu. Plus 6 more kwh to run the whole house basics plus 5 more when hot water/TV/cooking is needed aka gf is visiting.
