D
Deleted member 1888
Guest
Also I have 4x 100w panels on the way so ill have an 800w system heheheheh
Very thorough, clear and detailed system description, thank you. Sensible equipment selection as well. I only see four terminals on your SCC; panel input and battery charge output. Does this mean that your invertor is connected directly to the battery? Also, your lifepo is a 'deep cycle", how so, I thought that the lifepo's in general had pretty much the same discharge specs.? Have you, or do you expect to experience low solar gain periods that will not provide sufficient power to keep your freezer on?My system is up and running my freezer!!!!!!!!!
My system
- 4x 100w/17.8v/5.62amp Richsolar 100 Watt Polycrystalline 100W 12V Solar Panel (will build it to 1200w later)
- Renogy 20Ft 10 AWG Solar Panel and Controller Connector Adaptor Wire MC4 Extension Cables
- EPEVER 60amp MPPT Charge Controller 48V/36V/24V/12V Negative Ground Max 150V 4500W Input fit AGM/Gel/Flooded/User Backlight LCD Display Large-Amp(60A-MPPT) Max Input Solar Power: 1225W(12V); 2250W(24V); 3375W(36V); 4500W(48V).
- GoWISE Power PS1003 Pure SINE Wave Inverter 2000w Cont/4000w Peak
- WindyNation ANL Fuse Holder + ANL Fuse (2pcs 100A Fuse)
- Battle Born LiFePO4 Deep Cycle Battery - 100Ah 12v(1 to start will add more as I can)
- Blue Sea Systems Common BusBars (100A-250A)
- 2 feet 4awg wire with copper lugs form home depot
- 4 feet 2awg wire with copper lugs from home depot
View attachment 2563View attachment 2564View attachment 2634View attachment 2635View attachment 2636
I updated the main post with the new info.Very thorough, clear and detailed system description, thank you. Sensible equipment selection as well. I only see four terminals on your SCC; panel input and battery charge output. Does this mean that your invertor is connected directly to the battery? Also, your lifepo is a 'deep cycle", how so, I thought that the lifepo's in general had pretty much the same discharge specs.? Have you, or do you expect to experience low solar gain periods that will not provide sufficient power to keep your freezer on? ☮
In 24 Hours if pulls 2 KW(2000w if im converting that right) So I needed 200Ah or more to run it. I was not running it till now we will see how imt handles it.What is the running watts of the freezer on the AC line side?
in 24h it may pull 2KWh... not 2KW... 200Ah would store 2.8KWh if charged to 14.4vIn 24 Hours if pulls 2 KW(2000w if im converting that right) So I needed 200Ah or more to run it. I was not running it till now we will see how imt handles it.
I call GAS!!!!I just ordered 4 more 100w panels for $76 each, I DON'T HAVE A PROBLEM!
You should gets some TUMS that will hell your gas.I call GAS!!!!
But what will help YOUR GAS? Apparently you've got a fever, and the only prescription is more solar...You should gets some TUMS that will hell your gas.
I require more vespene gas, you know that.But what will help YOUR GAS? Apparently you've got a fever, and the only prescription is more solar...
