I have this system, I'm wondering if I can just connect wires between these 2. The anderson connector from battery (12v Owl Max) which has BMS & the AC200Max. I should be able to connect directly without wiring anything between. Would I be correct in the assumption. Just the large anderson connector to XT90 I have 10ga black & red wire, I'm just not sure that will be large enough. The XT90 I have looks like that is as large a wire as it will accept. Any and all help would be greatly appreciated. Thanks in advance. Doesn't the BMS ( on the battery and AC200) regulate by temp or do I have this all wrong?
