Stephen Shreds
Shreds
Um I have lights and a fridge and a fan tied into 12v then my inverter. I can try not to turn on my inverter for a few days and see if that increases the charge.You have 12V, 400 Ah, 5 kWh.
Charge controller showed 1.14 kWh for the day.
If no loads, in 4 or 5 days battery should be charged, unless voltage is insufficient; in which case you'll see kWh for the day taper off.
Or unless you keep draining it. What loads does it power each day/night?
You now have a tank of heat to somehow circulate though tubes under your bed.
I am good. I paid a lot of money for my setup. I also don't feel comfortable sleeping on a pressurized system.
