Stephen Shreds
Shreds
I built a large battery in parallel series (4x double 100ah cells) so 400ah battery this past february to put in my van I have 900w of solar on top. my battery has been sitting around 12.8 volts when i check my mt-50. I ran my espar b5e heater last night to make sure things are running properly before winter hits. the heater worked great. bring my van from 45~ ish to 80F. I woke up and turned on my hot water kettle and half way through my water heating process my system starts beeping at me notifying the voltage is low on my battery. I looked at the voltage and it read 11.6v's. I looked up my w/h on my espar unit and its around 32-50w/h with a big 400ah battery 400ahx12=4800 of w/h to play with. 50x8hours is 400 watts. my water kettle is 120v 1000w's. would this really brig my battery that low? ( i know having a electric water kettle is a luxury item in a van and i could use a jetboil if need be but i like the convenience)
real question. am i overestimating my my battery should be able to handle or is there something i am not seeing here? if i have to run my heater 24 hours a day for -30f days am i screwed for winters here in alaska? its been pretty cloudy the past couple of days but i didn't think it would effect my panels that much.
