The peak voltage any PV panel generates is achieved really quite early on in the morning and stays pretty stable into the evening, only the current really changes with differing solar irradiance levels. You don't often see this because the MPPT controller artificially modifies the PV voltage when trying to identify and track the maximum power point.
They look in parallel to me... ??
Do not guess, read your inverter's datasheet.
A solar charge controller [that supports multiple battery system voltages] doesn't care whether you connect a 12V (nominal) or 24V (nominal) battery system to it, but your system design as a whole does. For example, your charge controller has a maximum 40A charging current which means that it can only deliver 584W into a 12V (nominal) battery. If you connect more than 584W of PV, it will just clip the input (
up to the maximum PV power specification) so some of your 800W array will be 'left on the table'. With a 24V(nominal) battery it can deliver 1,168W. Additionally a 24V battery system would require thinner, cheaper cable. BUT! With a 24V battery system you would need to add a 24V-12V converter to your system to power any 12V loads you may have. My rule of thumb is:
1W - 3,000W: 12V battery system
3,000W - 5,000W: 24V battery system
>5,000W: 48V battery system
Your 3,000W inverter is right on the boundary. I would be asking myself, do I really need 3,000W of inverted power? The bigger the inverter, the more losses will be incurred, and the grater will be the quiescent (no load) draw constantly draining my battery.
Other considerations:
- Keep the higher voltage cable runs longer i.e. array-to-SCC: long, SCC-to-battery: short.
- Every circuit leaving your battery should be fused
- Consider adding isolator switches to all sources of power
- Use busbars instead of direct cable-to-device connections
- Consider adding 'split-charge-relay' system to charge your battery (if staying at 12V) from your alternator. DC-DC charger if 24V or you switch to lithium-ion.
Good luck with you project.
