NCblueridge
- Jul 31, 2020
- 154
I am building a small portable power station that will be used as a power source for my kayak's trolling motor and fish finder as well as a small backup system for power outages.
For my kayak uses, this will plug into a single outlet on my Slayer Propel 10 kayak and suppy power for a 12 volt, 30 amp trolling motor (Newport Vessels 36lb. thrust Kayak Series), a low power GPS/sonar unit (Dragonfly 5) some USB convenience connections I am adding to the kayak in conjunction with this project. I will probably do a post or two about that in this thread also.
For power failure situations, my primary needs are USB charging for my laptop, phone and iPad (I am a career long web developer and manage 19 individual data driven dynamic websites so access is critical), DC power for my fiber modem and router (both adapted to allow direct DC inputse) and power for a couple of DC fans and LED lighting. I also have a small external 750 watt inverter that will plug into the unit should that be necessary.
Charging sources for this station will consist of a Victron Bluesmart 12V/17Amp AC unit for regular use and (2) portable 100 Watt mono panels (or optionally (4) portable/stationary 100 Watt panels in a 2P/2S configuration ) with a small Victron 100/20A MPPT charge control which could possibly be integrated into the pack also.
The batteries I am using are (4) 105 AH Shenzhen Luyuan 3.2 Volt packs in a 4s configuration. I chose these for their light weight and size although the threads are fairly small as was pointed out in one of Will's build videos on youtube. I sourced the batteries from Power BLS on aliexpress since they have a US warehouse and offered free shipping for around $450.00. I wasn't happy with the mismatched cell voltages initially but otherwise they were new and the vendor has assured me that if there are any issues they will take care of them - I will know more after some capacity tests and use but for now they seem ok. I have top balanced these in parallel using a 100/30 bench power supply at 3.65v. I am using an Overkill BMS which I have been impressed with so far - more on that shortly.
So let's get started.
Battery specs:
Battery specs:
