Lernfaehig
- Jul 31, 2021
- 8
Hello everyone. I've experienced that a lot of solar power stations have issues with solar panels when the sun is coming up or going down. 3 of the ppwer stations I've tested make clicking sounds every few seconds as the MMPT charge controller realizes voltage is coming in but then the amps are too low to charge the battery and it turns off again.
I've tried finding a commercial product that would read the current while the panel(s) are connected to a dump load and only connect the panel(s) to the charge controller once there is sufficient amperage vailable to start charging. As I didn't succeed to find something like this I've created a block diagram but unfortunately lack the electronics skills to verify my idea and create a custom pcb for it. Additionally it should be very easy to use this same setup to implement low-temperature charging protection for systems not originally supporting it.
I'm hoping somebody here with better electronics knowledge than me can verify my idea. If you think think this could make a viable product you're very welcome to "steal" my idea make it into a commercial product ;-)
