berksrunner
- Jul 27, 2020
- 122
Has anyone thought of inventing a hot water heater for mobile applications based upon microwave technology????
How can you beat the 100 % efficiency and simplicity and low cost of a resistor? (excluding heat pumps of course) well, you can't. That's why everything that needs to heat water, and which doesn't use a heat pump, uses a resistive element.
I should also state: It's only 40-50 minutes when heating from ambient -- the maintenance of an already-not tank of water is far less (otherwise the draw would truly make the fully electric tank-based Bosch unfeasible for most battery banks/systems, at least at its highest setting.hmmmm. I think we need more context. Let's assume a hot water tank approach, something like the Bosch units, as opposed to on propane-fueled on demand. My van has a Bosch 7 gallon tank. If I want hot water (as opposed to lukewarm) I need to crank it to the highest setting, which draws a steady 1,400-1,600 Watts for 40-50 minutes depending on ambient temps. I'm willing to bet that microwaves, while drawing a similar amount, would draw for a significantly smaller period of time.
Simple math exercise:
1500W of power consumption applied as direct heating = almost 1500W of power applied to the water.
1500W of power consumption applied as microwave = about 1000W of power applied to the water.
Microwaving water is one of the most inefficient ways to heat water. Direct heat application is highly efficient.
As you mentioned yourself, the microwave takes a similar 1400-1600W of power, but it only heats the water with 1000W due to the gross inefficiencies of the microwave. In your 40-50 minute example, a microwave would run for well over an hour.
The answer to the question is "stupid" if the goal is to use less power to heat a given volume of water.
hmmmm. I think we need more context. Let's assume a hot water tank approach, something like the Bosch units, as opposed to propane-fueled on demand. My van has a Bosch 7 gallon tank. If I want hot water (as opposed to lukewarm) I need to crank it to the highest setting, which draws a steady 1,400-1,600 Watts for 40-50 minutes depending on ambient temps. I'm willing to bet that microwaves, while drawing a similar amount, would draw for a significantly smaller period of time.
You should ask yourself if you're okay with putting this out into the world with so little thought. You don't even bother with basic research before thinking you have the potential for genius. My presumptions aren't presumptions. They are facts. Opinion or fantasy does not change facts. A microwave uses 50-60% more power than it can output as microwaves. Period. The conversions necessary to take electrical input to microwave output are grossly inefficient. Microwaves are used because they are convenient. Their efficiency sucks.
No you can't apply it to the entire volume. Matter is a barrier to microwaves. Water is the best barrier of all for a microwave tuned to heat water. When heating water in the microwave, the water closest to the emitter gets warmer first and shields the water "behind" it relative to the emitters. The water below it heats through conduction from the adjacent molecules and what little natural convection can occur... JUST LIKE A TRADITIONAL WATER HEATER - the water at the element heats first and it radiates outward. One could argue that this more efficient because the heating element radiates in all directions vs. the microwave heating radiating only in the direction opposite the emitter.
In what would you house this magical device? Metal blocks microwaves. Would you put the entire microwave including its 5600V magnetron INSIDE the water heater?
Again, to answer the question: Stupid. I'm trying to be polite by not using colorful adjectives.
Again, thank you for the flaming...as if titling my own post as potentially stupid at the outset -- implying beforehand that I was NOT informed prior to making the post -- was not enough. Again, thank you!
