Hello solar enthusiasts.
I've been learning about solar stuff for the last year (started in December 2022).
I started with 1 battery, 1 2000watt pure sine inverter & 1 100watt panel.
I since replacement that panel with 5 active, 230 watt panels (1150watts).
I had a couple used batteries, given to me by mechanics and they seemed to work well.
Late spring 2023+ through the summer and fall in south Ontario Canada, with a lot of consistent sun, things were going well beyond my expectations.
I was able to plug my kitchen fridge in 12-14 hours a day + all washing machine loads were all done with solar.
All usb devices were charged via solar.
We had a couple experiments where we plugged the living room tv + laptop into solar in the evening time and it worked (5 hours solid).
Numbers on the controller were solid 12's-13's an 14's.
Winter in south Ontario is often really cloudy (for months).
During winter, we haven't used the solar much.
The batteries kinda charge through the day...but not much. Barely able to charge our cellphones...so I've left it (making sure the controller keeps above 11 & 12).
The system shuts off if it dips under 10.5.
In the last couple weeks. We had a couple days when the sun was OUT, all day.
For the first time in months, the controller is showing numbers back in the 13's.
I currently have 2 Canadian Tire batteries and 3 princess auto batteries, plugged in parallel (red to red to red, black to black to black).
Yesterday, I saw the controller at 13.
I've been able to use my washing machine at that level of charge.
So...I happily did an extra small wash, mid day, not a cloud in site. Nothing else plugged into the system.
I spent time last week, making sure all the batteries were topped up with distilled water.
Even the lowest ones weren't that low.
The washing machine didn't last 10 minutes before the inverter started beeping and the controller was at 11.
I've been anxiously awaiting the sun to start coming back and start using the solar again. I've been building the battery bank up through the winter.
We have 7 total batteries.
I'll have to find the battery model numbers and specs to share with you.
The batteries charge fine...but they seem to lose charge too quickly.
Am I doing something wrong?
My oldest battery is 1 year old.
The others are all 6 months old.
Thank you for taking the time to read.
Any information you need, please let me know.
I'm anxious to get this thing working properly.
EDIT
I've got 2x moto master batteries, connected in parallel;
MOTOMASTER NAUTILUS Group 31 Deep Cycle Battery is a premium deep cycle battery
Engineered for power, stamina and reliability
Provides extended runtime for \"house\" accessories such as trolling motors, refrigerators and electronics
Group size 31
800 marine cranking amps, 100 amp hours, 185 minute reserve capacity
Dimensions: 13\" L x 6.75\" W x 9.50\" H (330 x 171 x 21mm)
Accessories ListTerminal Hardware
Advanced FeaturesCarry Handle, Serviceable Electrolyte
Amp Hours (10 Hour Rate)0.00 Ah
Amp Hours (20 Hour Rate)100.00 Ah
Amp Hours (5 Hour Rate) 0.00 Ah
Battery Capacity (@25AMP)190 A
Battery Capacity (@75AMP)0 A
Battery TypeWet/Flooded
Battery UseCycling
I've got 3 pro point batteries (currently disconnected in a desperate attempt to process of elimination, wondering if the moto master batteries, themselves will work better)
EDIT
Group size 31
Battery UseCycling
Item Name | 27 DC Deep Cycle Battery |
Cold Cranking Amps (A) | 675 |
Type | Deep Cycle Battery |
Part Number (BCI) | 27 DC |
Case Colour | Black |
Packaging (qty) | 1 |
Voltage Rating (V DC) | 12 |
Case Material | Polypropylene |
Reserve Capacity (minutes) | 180 |
Battery Type | Lead acid |
Cranking Amps (A) | 840 |
Dimensions (in.) | 12-13/16L x 6-3/4W x 9-13/16H |
