rebelrider.mike
I was all set to buy a different inverter, and found out it didn't have ground fault detection or arc fault interrupt. But the EG4 18k does, and is only just outside my price range, LOL.
The manual is pretty vague about the unit's rapid shutdown capability. Fortunately, EG4 released this video a few days ago:
I guess the fellow is saying that there is a Tigo-compatible RSD transmitter built into the inverter? I'm guessing that it sends the "all clear" signal out through the PV conductors like the Tigo RSD transmitter would do. I'm thinking of getting the CCA, TAP, and the TS4-A-O modules, so that video helped a little. Though, I don't follow exactly how he hooked up the inverters RSD button to the external one, or why.
I'm also following the zero export issue here with interest. I haven't decided whether to sell back to my utility or not. But I do want grid input for when solar isn't plentiful. I'll be outputting to a sub panel rather than the main panel. I needed a sub panel anyway. My old breaker box is full of new breakers as I upgrade the wiring in my house. Ironic, because I'm actually using less electricity as I make those same improvements.
Something I'm not sure of is whether or not this inverter can use solar and grid to power the load at the same time, or if it switches back and forth. From what I've seen, most inverters share the load if solar is not sufficient (at least that's one possible setting). The language in the manual for self-usage mode is this:
"When solar power is not enough to take the load, the solar and battery will take the load together. If the battery is empty, the grid will be used to power the loads."
"Take the load together" vs "the grid will be used". The grid will be used to supplement the solar, or used instead of the solar? Either way, I'm not sure its a deal breaker. More of a curiosity.
