I ran a load test yesterday on a 250A Daly smart BMS without fan.
I depleted a 4S 272Ah bank at about 2kw.
After 30 minutes or so; the BMS cables started to heat up.
Not extreme but they reached about 45°C. Measured with an infrared thermometer; but it felt hotter.
The 2AGW Cables for 30cm, on 180A would loose about 0.1 volt; which is about 20W Produced heat (each).
Would it make sense to add a second extra wire to the BMS terminals? And how to best connect it?
Note: battery would be used in an RV with biggest consumer a 1800W microwave/oven combination. So it will occasionally run the higher loads for 30 minutes (but not constant the highest load).
Walter
Walter
