First and foremost, I'm looking for reliability. If I can do this at a low cost then great, but I don't want to buy something cheap and not be able to trust it.
My setup is 8x Sinopoly 200Ah 3.2v cells set up in 2P4S to make a 400Ah 12.8v battery.
I have a Magnum 2000w inverter that powers a 1400w electric hot water heater, a 1800w toaster oven, a 1300w microwave, and a ~1200w induction cooktop (one at a time of course).
Currently I don't have any individual cell protections or balancing in place and I think it would be nice to have these things.
Right now I just have low voltage protections that cut off below 12v: a Victron Battery Protect for 12v sources, and my Magnum inverter for 110v sources. I have a Victron 702 and temp sensor that triggers an alarm for high and low voltages and temperatures, but they don't do anything.
So... I know Will and others talk about the Daly BMS -- they have a 200A 12v version -- is this a good choice to handle 150A max (for 10-15 minutes maximum)?
Is getting a smaller Daly and wiring in a 200A relay to operate the switch any more beneficial? Seems like one more component to wire and worry about.
Also -- AliExpress specs on the 200A version say it does not have temp protection, and additional modifications are needed for it to work. What does that mean?
Daly 200A 12v BMS: https://www.aliexpress.com/item/32852570488.html?spm=a2g1y.12024536.productList_8288666.subject_4
Are there any other BMS that I should consider?
I've been using this setup for about a year now full time without a BMS but have hiccups every once in a while and a BMS should help automate and correct for this.
*bonus question: any suggestions on how to make DIY compression straps/plates on a 8 cell setup that arranged 4x2?
