AGDorsum
Located in Tri-valley east of San Francisco. In 2012 we self-installed an Enphase system comprised of 20 250w Canadian Solar panels, 20 M215 GT inverters (2012 vintage so no throttling, on/off only), and an Envoy. In 2018 we upgraded our Envoy to an Envoy-S (with combiner box)and added a 1.2Kw Enphase battery. Panels are configured in 2 strings, 5 on garage and 15 on house.
Production/consumption are as follows:
Annual - 6.6Mwh/11.3Mwh
High Month - 781.6Kwh/1200Kwh
Low Month - 288.1Kwh/802.3Kwh
Avg/Day - 18.1Kwh/31Kwh
Our major issue is PG&E. We buy our electricity from a co-op, flat rate at $0.11 per KWh for the past 3 years. PG&E delivers the power through their infrastructure, for a fee. In 2020 we paid $0.235 for tier 1 and $0.296 for tier 2 per KWh net delivered. Fast forward to today, $0.282 for tier 1 and $0.355 for tier 2.
My question to this forum is:
What additional equipment/configuration is needed to increase production thereby reducing transmission costs Without breaking the bank. An added benefit would be to keep solar alive during grid outage.
Additional considerations:
Cannot reduce consumption, divorce will cost more than any upgrade.
No Enphase upgrade (cable, inverters, panels, and Envoy). Not an upgrade but a replacement of everything except mounting rails. Considering partial upgrade to 5 panels.
No room for additional panels.
With my (very) limited knowledge I came up with the following options:
Lots of creative, resourceful folks on this forum, let’s see what you have.
Thank you for reading if you made it this far.
- Replace 5 garage inverters/panels with IQ8 inverters and 390+ watt panels. Add Enphase Q-Relay-3P-INT (if I can find it in the U.S.) to disconnect grid. No reporting to Enphase. Trying to find out if grid forming IQ8 inverters will keep M215 inverters alive while grid down.
- Add inverter (grid forming) to AC-Couple existing Enphase, replace garage panels with 390+ watt panels DC connected to inverter. Battery required to keep inverter alive, not enough production to charge/discharge daily.
