Inexpensive 200 Amp 3-Pole Distribution Block for 4/0 Cable
Ryushin
Castle Rock, Colorado
I've read no so great stories about using Polaris connectors about how they loosen up over time. I have a manual transfer switch and I need a 3 pole tap.
Watching Engineer775 Youtube videos, he has been using some nice distribution blocks. I believe they are Mersen:
I've seen distribution blocks price to over $600. The Mersen is close to $300. Any affordable options available?
Perhaps I should just use a drop of blue locktite for the Polaris connectors?
Here is a link to a Marathon distribution block from Galco.com. This is one example they have a fairly good selection.
I did look at Galco. I may have missed it, but I could not find anything that could do 4/0 with a 1 into 2 3-Pole. I need to create a tap for L1, L2, and Neutral.
That link shows 2 AWG into two 6 AWG.
Input Wire Range600 kcmil-2 AWG
Output Wire Range250 kcmil-6 AWG
Input is 600kcmil at the largest to 2awg at the smallest, 4/0 is in that range. Output is 250 kcmil at the largest to 6 awg at the smallest, 4/0 is in that range as well.
Wire sizes above 4/0 specified in kcmil or mcm (same thing) that start at 250 and go up from there.
Unless I'm totally wrong about wire sizes:
From Small to Large:
10 AWG
8 AWG
6 AWG
4 AWG
2 AWG
0 AWG
2/0 AWG
3/0 AWG
4/0 AWG
Including wire sizes above 4/0 awg:
10 AWG
8 AWG
6 AWG
4 AWG
2 AWG
1 AWG
1/0 AWG
2/0 AWG
3/0 AWG
4/0 AWG
250 kcmil
300 kcmil
350 kcmil
400 kcmil
500 kcmil
600 kcmil
( and on thru larger kcmil sizes)
kcmil is also some times written as mcm
I did not look Ebay. Looks like a good source to find them. Price looks good too. It's not like these things can go bad.
So you want a single 4/0 in and 4/0 out preferably in a 3 pole block?
If so: eaton-bussmann-16306-3
Single 4/0 in and Double 4/0 out. I'll look there too.
