One thing I haven't been able to find much in the way of recommendations for, is how you should go about the initial charge and syncing of two batteries prior to cycling them in parallel. Is there a step by step process you follow to do it? I know some of the basics, like pre-charging both to the same voltage. But the nuances like how long after charging to let them sit, whether to charge or discharge the parallel pack after initial sync, things that can go wrong or to watch for etc. Maybe none of the details matter and the batteries will just balance each other out quickly? Any pointers here appreciated!
