Exactly how many Ah per day do you use? Running in a range of 100% to 80% is different than running in a range of 80% to 60%. The latter will sulfate cells excessively.
Our average is 100Ah deficit by sunrise. The monitor has never hit below 82%, and I have alarms set at 80.
A 'normal' day for us is waking up at 92%, sun rises, we hit absorption within an hour or two depending on clouds, and sit at the temp compensated Absorb=Float voltage for the remainder of the day. That will eliminate all but ~35 Ah of the deficit before sunset, as the current is only 4-5 Amps at that point to maintain voltage.
I would press them at least once a week to the magical 100% charged.
Tried it in the early morning hours this weekend and the charging performance was almost identical to just a sunny day. Hit the absorb limit maybe 30 minutes faster than the MPPT, and then it's just watching decreasing tail current. Eventually I just switched back to the MPPT since it's a better charger (vs. the Trace Xantrex SW4024), and the giant loud LP generator was only sending <200W to the batteries on a bright sunny day.
If you don't have enough recharge capacity, then you should add some. PV panels are cheap, ground mounts can be inexpensively built with just lumber.
I have 1500W on right now which seems to be doing the trick - or at least as well an LP generator. I had ordered 6x 455W panels that arrived smashed before I found these batteries - seems like that would have been a waste on this bank!
Eventually replacing with LFP batteries, when needed, will eliminate the AGM need to get 100%
I'm excited to see how the current setup performs over time. I paid ~$50/kW for these, cabling included. These are meant to bridge us until the completion of an addition to the cabin. Our priority was initial cash outlay since the future is murky. We might watch them fall off the cliff, but at least I think we know what we're looking for now!
We live on a former ranch inside of BLM land (Central CO, 9000'). All of our neighbors are off grid as well. It's absolutely bat**** crazy to see our neighbors hitting low voltage and using their generators DAILY with much higher end equipment, plunging thousands of $ each week in having solar installers coming and 'tweak' their setup to try and get by. You all and this forum rock!
