Nomad76
I have an idea for an off-grid solar thermal power generator - something small scale, just enough to power a sensor or maybe a camera - with no external panels or anything obvious other than a ground level concrete pad (which could also be buried under a couple inches of dirt).
I had thought this up as just a design exercise. The idea is to use the temperature differential between day and night to generate a small amount of electricity to keep a small battery charged to power a minimalist monitoring system. The point is to have this system work without any outside visible features for a buried, hidden facility.
My initial purpose was to maintain a primary monitoring system for an off-grid, subterranean structure. I wanted a way to monitor the status of the structure while I am out of the country. I want this to have no externally identifiable features to keep the facility hidden to casual observers. There would be a secondary, more robust alarm/monitoring system which is dormant until the primary system is triggered.
My question to the forum - can you think of any other applications for this kind of power generating system?
