I have a Sungold 3000w 12V inverter/charger that I'm getting ready to put into my RV. I'm trying to put it through the paces to make sure I have all my angles covered and I did a discharge cycle on my lifepo4 pack until the BMS shut off the discharge due to low pack voltage. (BMS is a common port for charge and discharge)
The issue I'm running into is that the inverter/charger will not turn on at all unless it sees battery voltage on the 12v terminals. So, it will not turn on and charge the batteries because the BMS isn't letting it see 12v and it won't turn on even with shore power. I hooked up my bench power supply for a second to the terminals and woke up the inverter. Then it started charging and the BMS turned back on the discharge and everything was back to normal.
I'm wondering though what would be the proper way to design this into the system in my RV to overcome this condition? I'm thinking maybe a pushbutton switch to temporarily bypass the BMS? I'm concerned about possible overload of that switch though, especially if it was pushed when no shore power was available.
Any ideas? I haven't been able to find any answers on the forum, but I'm also not even sure how to search for this.
