Inverter drawing power from batteries more than load power
mahmoudad
Lebanon
I have a must pro pv1800 5.2 kw off grid. The battery power is around 130 watt greater than load power. This started 10 days ago. Is this a cause of concern
Probably not. What load are you powering? 55% efficiency at 3% rated load is not surprising. Try to power resistive heater at 2kW and check these numbers again.
Could be measurement error. Typical standby power of inverter of that size is around 60 watts.
