HarryN
I read today 1ft vs 3ft in 10awg is nominal loss so I will do that. Thanks
Yes - there isn't any downside.
Longer term, you will want a way to separate each battery from the system, either with a fuse or breaker.
One reason is for safety - as your set up is perfectly capable of evaporating those wires and that can be exciting.
The other less obvious reason is that inside of most LiFe consumer batteries is a BMS that trips it off when it detects conditions that it isn't happy with.
The way that these are re-set is to disconnect the battery from the circuit. You can do this using tools but sometimes it is nice to just flip a breaker switch or pull a fuse.
___________
Here is an example of twisted pair wiring in case anyone needs it for a reference in the future.
![en.wikipedia.org](https://upload.wikimedia.org/wikipedia/commons/thumb/3/35/25_pair_color_code_chart.svg/1200px-25_pair_color_code_chart.svg.png)
