ArmyRetired
- Jun 14, 2021
- 17
Last fall I installed solar, an SOK 206 battery and an MPP 1012 all-in-one in our RV. Solar charging of the battery works great. Problem is I can't seem to get much useful A/C out of the inverter. It hasn't really been that big of a deal, but I would like to get it right. I can get the outdoor kitchen mini-fridge to turn on and I can get a hairdryer on low to turn on, but anything with any kind of chip doesn't seem to work. The microwave freaks out and has a constant beeping so bad I have to turn its breaker off. Not trying to run it mind you, just the clock or whatever is on prior to actually microwaving things. I can't even get a small 700w coffee pot to work.
I'm afraid I've wired something wrong, the inverter is just not working, or an incorrect setting on the all-in-one. What I'd really like to run is a small dehumidifier but that doesn't work either. I tried my multimeter in an A/C outlet (set to ACV) but the readings were certainly not what I would expect. About +/- 4 or 5 volts. Nothing consistent.
Any help would be appreciated.
