I recently wired up two inverters, the EG4 3000 yellow ones and was curious about inverter power consumption expectations.
Before: 1 inverter power consumption + general things like the freezer/fridge/etc would take around 10% of the battery capacity over the night.
Now: 2 inverters in split phase power consumption + general things like the freezer/fridge/etc would take around 18% of the battery capacity over the night.
I understand that the second inverter constantly being on would consume more, but was curious if there was additional losses when the inverters are trying to keep the sine waves in split phase vs. just a parallel mode. I wouldn't need the 240V often, so I could swap modes before flipping on that breaker and leveraging 240 if that would help with the power consumption.
Since % are kind of meaningless, and 10% for 1 and 18% for 2 actually seems reasonable if there weren't really any other loads, I'll give a little bit more detail. It's a 15,360Wh battery array so 10% would be ~1536Wh and 18% would be ~2765Wh. Looking at about 14 hours where it stayed mostly idle to use up that amount - 110Wh/hr vs. 198Wh/hr. Idle power consumption (though not truly idle? Plus added strain of making sure phases are aligned?) for this inverter is listed as <50W.
Question: Think putting it in PAL mode instead of 2P1/2P2 would reduce power consumption?
