JohnBrother
Hi,
My design is as follows.
4 x 460W panels in 2S2P configuration, 2 panels in series facing South East and 2 panels in series facing South West - I reckon this is going to help to even out the generation. I don't think like 45 degree but maybe 30 degree or even less.
1840W
98Voc in 2S2P configuration, 147Voc in 3S2P (future) configuration.
I want to leave some room for growth to add 2 more 460W panels so 3s2p.
For that I decided to go for Victron MPPT 150/100 battery charger.
My estimated energy usage is 4800Wh (24x 200W) at home. The purpose is to power on 1 laptop, 1 PC, lights, network equipment (router, a switch) with a microwave for couple of minutes. I could experiment with larger appliances like a washing machine and fridge but only when the batteries are full and the sky is clear.
I get about 560Ah worth of batteries. 2x (2x 280Ah 12V batteries in series for 24V) then these two in parallel to get 560Ah.
I was able to find a suitable MPPT with room for growth but I cannot find an inverter that can cover up to 3000W when I add 2 more panels (2760W).
I don't think I would ever need to go over 3000W. I cannot find anything from Victron or it is crazy expensive or a 48V system.
When I look at it I am a bit confused what is the difference between so called power inverters, battery inverters, off-grid inverters.
How I understand it I should go for a battery inverter.
There are also these hybrid inverter+MPPT combo boxes.
Ideally with an uninterruptible switching from PV back to grid but Victron Energy MultiPlus-II 24V 3000VA 70A 32A is pretty expensive so a plain transfer switch in case of a failure or a maintenance would do (for now).
I think before the upgrade I could do with Giandel 2000W 24V inverter.
What would you recommend?
1840W
