Inverters High or Low Frequency ?
I wonder how the two inverters communicate between each other… the house must have shared neutrals… even if they are not bonded to ground… so all panels combined need to be in sync
they do not have the communication problem solved.....still tinkering with it over 2 years later....as I understand it....
none are at the delivery stage yet...
kind of like the incompatible parts in the personal computers through the years>>> their redesign of an old design based on the original xantrax inverter copy I think
I am not an electrical engineer >>> so above my understanding of the tiny pieces and parts to make that function correctly...
low frequency >>> a 48 volt 20kw LF PSW SP 2 ss box Super Power Brand supposedly in North Hampton PA today? if it arrives $508.90 via eBay auction...
I think it is set up like the AMG version just like the upower topic that was being discussed...
I thought it was another fraud scam,,,, and started to cancel through eBay,,,, but it seems now to be showing up
I still think it is the same PowerJack manufactured units...
eta 2/17/2023 via FedEx???
I am thinking the other forum just deleted what they did not like,,,, kind of the cancel culture if one disagrees....
I like the 2 box design of the 15k inverter I am running.....
the other forum seems to purposely give bad direction...
WEIGHT51 lbs / 23.13 kgs
DIMENSIONS23x22x13 in.
TOTAL PIECES2
TOTAL SHIPMENT WEIGHT87 lbs / 39.46 kgs
PACKAGINGPackage
so it looks like it will weigh 138 pounds for this toroidal based 2 box inverter according to the FedEx site. it is in Kansas city now...
Common issue with these large LF toroid transformer designs is the mounting straps. Gentry and Powerjack inverters have this arrangement.
If the center bolt makes contact to the perimeter metal support straps you get a short circuit secondary side turn on toroid transformer made of conductive straps, center bolt, and metal case. This causes a massive inverter DC input current that can blow out MOSFET's on primary side.
When this happens, overcurrent protect on AC side current sensors are not in short circuit load path so they will not shut down inverter to protect it. Not many inverters put independent primary side MOSFET overcurrent sensing protection, other than temp sensors on their heat sinks, so DC input breaker is last line of defense, which if it pops is usually after the MOSFET's are already destroyed.
It is better to have an isolated center support cup without perimeter straps to short out for mounting of toroid transformer.
Whether LF or HF inverters, poor quality designs on either will dominate results.
As to solid design and good quality, I would rate Victron(LF), SMA(LF), Xantrex(LF), and Outback(LF) on the top of the list. SolArk(HF), Magnum(LF) in middle. AIMS(LF), MPP Solar(HF), Growatt(HF), and Powerjack(LF) near bottom of list. A lot of HF inverter clones are very poor quality.
at around 6:23 in that video above he is showing some of what not to do but does not know what it is....or why they blow up all his fets in his inverter...
there is a reason that DC switches and DC breakers are heavy-duty >>>> the dangerous arc flash is just one of the errors to avoid...
I have a 600-volt DC 200amp switch coming today.... made by Square D...
not el cheapo garbage
the shunt on the DC breaker that was not installed correctly or safely had a loose dc connection. he does not know what the shunt is....
shunts are commonly used to get measurements across different points.....
he utilizes the more dangerous used Li-ion battery technology....
the dc arc flash is no joke....
DC breakers should be in a steel enclosure for safety and all connections carefully checked before energizing,,,
safety 1st....
DC voltage has my respect....
as does AC voltage
be safe in all you do....?
Wait these guys are trying to design an inverter and they don’t even know what a shunt is?
What is the background on these 2?
Where did they come from?
Why have I never seen this before?
one guy is in Ohio and may have been a back shed forum self-teacher who worked for PowerJack but may be a carpenter but not an engineer, the other is/was a retail store worker who also worked for PowerJack is in Lansing Michigan,,,, now both bash them after PowerJack gave them the Chinese handshake. the front man in the video sales man was touting PowerJack in many videos and PowerJack was sending him returns to fix etc,,, but then after trying to be a competitor, it seems PowerJack gave them the Chinese handshake....after getting some preorder money in August 2022....at 3000 dollars per preorder not yet produced hyped gs12k inverter....
still none have been shipped for final production...
selling things they do not have produced.....
presales without the goods
sound familiar??
before the honeymoon he (the front man) was going to have a retail store funded by PowerJack >>> all went south for him for a faster way to sell stuff.. in a nut shell as they give all kinds of directions right and wrong ??? to the YouTube audience....
one guy commenting is the front man salesman's is their new neighbor down the road....in Michigan also....
search powerjack inverter on YouTube....
176 pound 30000 watt lf psw sp inverter 2 stainless steel cases shipped 2/16/2023 via Philadelphia PA fedex toroid inverter....
so this was via a eBay auction for $966.81 delivery and taxes included 48 volt inverter purchase 12/5/2023 so it takes a while via the slow boat ride.... from China
30000W LF SP PSW Power iIverter DC 48V To AC 110V & 220V-Forver version
Interesting. Have you tried it yet?
30000W LF SP PSW Power iIverter DC 48V To AC 110V & 220V-Forever version
The picture of the transformer on pallet sent to Sid is the ASL 11.0 in your 30kw Powerjack . Jack lie to Sean and Sid and maybe copy the winding spec of the GS12kw ? Your 30kw may do 12000 watt for an hour ?
Thanks for posting these Block Diagram.
Very helpful in understanding the process.
for less than 1/3 of the prepay not yet existent none yet shipped redesigned GS12k....>>> ($2999.99 plus tax)
watching them show the inverter again with blown mosfets and the improperly secured dc breaker makes one shake his head in disbelief...
eBay and pay by credit card is the guarantee.... of product delivery
vs the prepay to a not yet produced pie-in-the-sky inverter...
you would have to hope those people who have the prepay since August 2022 get the end product....
yet he is still trying to get more people to pay in advance for nothing yet produced or proven reliable from new and different pieces and parts suppliers from China... and still, have to wait on a slow boat ride when and if they get all the pieces and parts...
why did their gs12k prototype inverter blow up all the mosfets >>> they don't know.... not the first time either...
gs still tinkering with their redesign of the wheel for over 2 years and lost the prior manufacturing partner for various unknown reasons....
selling used or decommissioned PowerJack parts on their website with absolutely no warranty???? hmmmm
did PowerJack just loose all the pallets of parts he shipped to GS ??
the Chinese handshake without a contract did not work out well for them....
gs avoids answers to what happened to the money the people paid on the pre-pay plan.... maybe Jack took them on a vacation....
gs says good luck trying to sue a Chinese company >>> duh
maybe/hopefully the 30000-watt LF PSW SP will run the welder and a few more shop tools.... there is absolutely never going to be any grid connection to these inverters in my solar PV off-grid builds... 12000 watts would be sufficient for the moment...?
it is designed to be readily opened and repaired >>>the 2 ss box inverter....
I will open it up and check it all before hooking it up.... after FedEx throws it down several times because they will not employ a team lift for it.... I have watched them do these drops right in front of me in my driveway before...
the Square D 600 volt DC 200 amp disconnect switch arrived yesterday via UPS.... safety 1st you all..
have a great day... its Friday! ?
I may answer this post with several posting as I may find more wrong with the GS12kw . First for less than 1/3 of the prepay not yet existent none yet shipped redesigned GS12k....>>> ($2999.99 plus tax) watching them show the inverter again with blown mosfets and the improperly secured dc breaker makes one shake his head in disbelief... YES and I watch the youtube before that Sean say he check every connection and all are tight including all DC connections and breaker are tight and good . After all 44 mosfets blown up he then say Ebay send him a broken DC breaker and something loose inside the breaker may cause the damage . One ( David H ) comment that the problem is cause by having both inverters share one and same battery bank . Sean did not answer ( David H ) and think his battery is ok and not the problem . why did their gs12k prototype inverter blow up all the mosfets >>> they don't know.... not the first time either... In the November load test of the prototype inverter and when the second inverter breaker turn on the inverter blow all 44 FETs and later say Darren fixed the problem then why the same happen again NOW and blame the DC breaker . What if a new DC breaker did not fix the blow up problem and later there are 4 inverters on the wall and then the next 3 inverters blow up 152 FETs when 3 breakers turn on but at least the first inverter never did blow up . The 2 previous time the first inverter never blow up either . Something to think about ?
low frequency >>> a 48 volt 20kw LF PSW SP 2 ss box Super Power Brand supposedly in North Hampton PA today? if it arrives $508.90 via eBay auction...I thought it was another fraud scam,,,, and started to cancel through eBay,,,, but it seems now to be showing up .
I won several Ebay auctions also . Tracking show they are in Chicago so I started to cancel through Ebay because of your post . Nothing was delivered for 2 months and when I cancel the seller say it is in Walnut and will ship today . Very strange and maybe a new scram is planned by Jack for his Ebay seller .
the tracking is the strangest i seen,,,, the fedex is sending it out today so i will see the 2 box 20k today
update: FedEx delivered the 22kg transformer 20k box , but the control box is not here,,, they snuck in and out without me seeing them,,, left it on a pallet next to the skidloader...
half is here>>> go figure,,, cant even get it on the same truck???
the 30000 watt 2 box ss LF SP PSW toroid-based heavy iron core transformer inverter Super Power brand (PowerJack build i am sure) may arrive on Monday or so according to its FedEx tracking both thru Philadelphia FedEx originally,
but I started to cancel and then they provide tracking a few days later....
eBay has the money-back guarantee plus I could employ a credit card company to sick on 'em if it did not show up...
multitasking with the rental house clean up(nasty people out there) and the farm animal care at the solar PV off-grid farm today.
have a great day ?
update: FedEx delivered the 22kg transformer 20k box , but the control box is not here,,, they snuck in and out without me seeing them,,, left it on a pallet next to the skidloader . Fed Ex ship half the shipment to me a long time ago and left in a hurry . Fed Ex drop a battrey and left in a big hurry and that battery blew up outside a long time ago . The ebay seller say Fed Ex will deliver by next week after I call Am Exp to cancel the order . Sometime and maybe all the time need to cancel before Powerjack will deliver .
20K modular 2 piece LF SP PSW inverter half is MIA:
I do note that it has a thick steel reinforcement plate on the bottom where the center toroid bolt holds it in place ( a known weak part to be checked before operation), so they have improved that on this version or at least made it stronger in that part....ASL6 I think it said on the bottom AMG version 11.3....so not a very large toroid transformer in it.... a single 120mm fan on the transformer box...
well, well, well, a shipping label was created for the control box but FedEx says they never received it, seller says they can send a replacement on the next ocean shipment, so I have a transformer box for the 20k but no control box ( not unusable) I was going to open it up but I better wait I guess( I did take it out of the double cardboard box but I was going to open up the metal case to see what's inside,,, this one has stickers and is a painted silver color likely galvanized metal, not stainless steel....
I think the 30k which is supposed to arrive on Monday the 20th of February will be in two ss cases in its two box shipment,,,, I will have to wait and see how FedEx does with the next shipment (kind of like cracker jacks)
but like you say when I started to cancel they suddenly found they were in the warehouse (they must have several warehouses) Lansing Michigan, Philadelphia PA, Walnut California etc
Maybe better to order one direct from the warehouse but often can be bought at half price on eBay auction...?
by the way >>> PowerJack / Super Power / uPower / etc are LF inverters with heavy iron core transformers (at least the ones I purchased; the PWM (pulse width modulation) is done 1st directly from the DC battery input cables and then the newly inverted PSW (pure sine wave) low voltage AC is ran through the split phase center-tapped toroidal transformer to increase the voltage output to 120 or 240 volts.... (a step-up transformer)
the control box will have the DC input where the PWM (pulse width modulation) occurs to invert the DC to AC voltage...(mainboard with the MOSFETs, electrolytic capacitors and blob capacitors to filter it, control board, and low-frequency driver board etc)
It specifically states a choke is needed on the AC output for heavy motor loads !!!! on the case!
for the USA 120 volt and/or 240 volts is all I use....at 60hz
I hook these up to off-grid main breaker panels and would never hook on to the grid... all is off-grid solar PV in my builds...
I found this thread to be quite informative when I went back to the beginning and read through it better,
thanks to all the commentors???
IS this Jack scam to not sell the 20kw inverter for a low auction price ? I already file a dispute with Am Exp on the item that the seller say I will get next week from Walnut . IF only control box was deliver then Am Exp say I will get a complete refund if the other item is not recieve within 30 days . IT do not make sense if ocean shipping take more than 30 days so I will cancel and return the item and try the next auction . Transformer ASL6.5 is very good but I never see a ASL6.0 . IF I do get the 2 boxes next week then I will test and see if smoke come out and file for a return immediately . I always turn the inverter on first and then turn on the AC breaker and not need a AC choke . When the AC breaker is turn on with a 5000 watts load first and then turn on the inverter the AC load sometime start slowly or a delay of a second and ramp up to speed . My 2 inverters has 2 separate battery banks so not blow up the inverter like Sean done two times . He blame the barn wires the first time and now say ebay send him a bad DC breaker and shunt .
IS this Jack scam to not sell the 20kw inverter for a low auction price ? seller say I will get next week from Walnut .
seems to be the same game playing>>>>why???
do the credit cards take the hit and the seller walks away never to return the money to the cc companies>>>just get a different new seller name on eBay???
I hope not but at any rate, there is a 2-piece 30k LF PSW SP inverter en route for Monday (according to the FedEx tracking) with a 176.24 pounds weight shown in the FedEx notice...
and maybe the control box will show up in another week or so for the MIA other half of the 20K modular LF SP PSW inverter...
Seller messageMessageMessageHi Sir If so, we did have 1pc stocks in CA warhouse, you still want another 5days around, if so, we will arrange it by next Monday, pls confirm, tks.
now they may have found the other half from CA warehouse....hurry up and wait,,,,I guess,
hope not to be scammed but eBay still says it has 30-day money back guarantee....but still annoying...
have a great day
Seller messageMessageMessageHi Sir If so, we did have 1pc stocks in CA warhouse, you still want another 5days around, if so, we will arrange it by next Monday, pls confirm, tks. The seller was hoping you will cancel first . When I was selling on ebay if I cancel a order FIRST then ebay will give me penalty . I always try to make the buyer cancelled first if the price is not right . I just happen to get a message an hour ago to cancel my low auction price item and want me to cancelled FIRST . I say NO and to send me the item . Now waiting to see if the seller will message that the item was lost and he need to cancel . Fed Ex forget to pick up the other box is a stupid excuse and now found one in Walnut is also stupid . I know that almost all item in Walnut are returned . You should test the control box as soon as it is delivered and see if any smoke .
I think they have bad communication of the inverter getting the back surge with 2 inverters hooked to the same battery and same ac breaker system even if one is a different subpanel they will still be electrically connected and not correctly synchronized as an earlier commenter mentioned. hard to say
I am not an electrical engineer, but try to learn more every day! ?
I use a different breaker panel and different separate LIFePO4 batteries for each inverter I connect and do not redline them.....
I prefer not to blow them up and definitely check the connections for secure and tight connections....
my LF inverters are off-grid and will never come in contact with the grid...
they have not cured their bug-ridden gs prototype woes after more than 2 years of hype.... and still guessing what the problem may be....blowing out 48 fets should be fun to repair???
he hides his dangerous Li-ion batteries connections.... in essentially all the youtube videos (red dot).?
